'83 380SEC AMG'ed euro, '92 500SL, '91 190e 2.6 5-speed
Hi everyone,
I've removed a gas tank from a '87 420SEL that was in desperate need of a flush. The tank cleaned up pretty nicely but there is rust inside (No flakes but will get worse if not addressed). To prevent problems in the future (The previous owner cut the strainer out...) I'd like to seal the tank. Given that w126 tanks are steel this shouldn't be a problem however the tank does have a plastic housing inside (Around the main fuel hose). I'm concerned that there will be an adhesion problem with any sealer if applied.
Have any of you had there tank sealed? If so, do you know if the tank was split to remove the plastic housing first?
I know best option would be to find a used tank without this problem but they aren't always available and if they are they have also been sitting with a galloon or two of old gas inside. As our cars get older restoring these tanks will become more common.
