1 - 9 of 9 Posts
Moderator
1995 Mercedes S420, 1995 SL320, 2000 Land Rover Discovery II, 1985 Lotus Turbo Esprit
Hi guys -- some confusion here when looking up part numbers for a purge valve.
When I look up a purge/regen valve on various (reliable) parts sites, I'm directed towards two separate part numbers; 000 470 22 93 and 000 470 87 93.
Some sites say that one is compatible but the other isn't, and others say they're both compatible. And FCP Euro says neither are compatible.
When I look on my car, the one I see is 000 470 22 93. But my question is, am I missing something here? Are these two distinctly different parts serving different functions? Or are the parts suppliers making a mistake saying one is compatible with my car and not the other?
I just want to clarify before I order anything.
94 SL320 98 SL500 99 SL600
AFAIK the difference is the plug look at the plug on yours and match it .
Moderator
My car has the plug with the round pegs like on 000 470 22 93.
If I were you I'd get a used one on eBay just match the plug and put a small plastic inline fuel filter on it between the valve and canister. You can test the valve by blowing through it while connecting to 12V.
Moderator
When I pulled off the vacuum hose I saw all those little pellets of carbon like you said. Can you point me towards an inline fuel filter that'll fit the application? When I look them up there are a million choices.
You can get it at any parts house. Clean out your Evap valve with a lot of electronic spray and test with 12V battery by blowing through it till it closes solid, The filter will fill up but no need to change, vacuum will pass through the pellets,
Moderator
Done and done, filter was just delivered yesterday, will install tomorrow.
Moderator
Yep, everything seems to be working, no more code, CEL went off. (y)(y)
1 - 9 of 9 Posts
