Welcome!
I'll work from the bottom up with whatever I can help with.
Speedometer, follow the speedometer cable down to the transmission, look for a "box", that might have what looks like two outputs on it, one might have a rubber plug on top, those need greased (like you have to physically open up the gear reduction box and put grease in it) sometimes and can be missing teeth, you may also need to lube the speedometer cable. They reduction box might not be there, if not don't worry not all trucks had them, just a place to start looking.
Tachometer. Not sure here, start chasing grounds I would say. Is it the kind that opens up (Tachograph) or just the standard tachometer?
Reverse switch is on the transmission, but check the wiring at the back of the truck and work your way up (after a quick visual of the wiring at the switch on the transmission). There might be a weatherproof box at the back up on the inside of the frame rail that has a bunch of wiring in it, worth a check.
Parking brake lever, no, shouldn't leak, nothing should really leak when just sitting other than the pop off valve once in a while popping off to maintain pressure when running. Rebuilt is likely in its's future.
Downshifting should be just as smooth as upshifting. When was the transmission fluid last changed? There are instructions in the service manual on adjusting the linkage for shifting, this can sometimes get out of whack if the cab has been tilted recently. Does the truck have the optional clutch pedal booster? Is it a double clutch or single clutch?
Also be sure to post a pic of the new beast!
