The W201 suspension has numerous jointed contact points, both front and rear, metal, plast...
The W201 suspension has numerous jointed contact points, both front and rear, metal, plastic and rubber. At your present mileage, you could expect that the ball joints in the front, the tie rod and possibly the sway bar/control arm links could all be worn and in need of replacement. In addition, checking the front end alignment and geometry should be done. Don't forget to have the rear 5-link suspension, the subframe mount and the differential mounts taken a look at too.
