1999 slk 230
Hi Folks,
1999 slk 230 115k Discovered PSE soaked in H20 removed and replaced with new one @ $450 online purchase.dealer asking $1200.
1)Anyways my battery is dead, is there any way this could be connected?
Boosted the car started fine, however everytime I step on gas it appears the light interior,and headlights brigthen up.....
2) I do not have my radio code, what is the fix for this?
Thanks in advance for your input!
1998 SLK230 240,xxx Miles
Check your drains and make sure there not clogged up.
if your battery is 5 years old or more replace it
or it could be a bad alternator.
go to a MB dealer with proof of ownership and they should give you the code.
1999 slk 230
Battery only 2 years old, I had the car running for about an hour would that be enough time for the alternator to charge the battery?
What are your thoughts on this being a coincicdence with my PSE being soaked in water- battery dying.
My locking system will unlock but not lock after replacing with a new PSE..... vac/battery related problem?
Thanks in advance
