1 - 10 of 10 Posts
Mercedes S500 - W140 && S500 W220.
Good Morning Gentlemen,
It seems the 220's PSE pump is end of life,
I opened up the PSE pump, the motor is fine, ( no burning, and runs smooth ).
The impeller however is worn out; thus the low pressure.
Upon searching, I found a British Website, selling just the impeller, and claiming their products are better than the OEM.
I wanted to know, the forum's verdict on this case.
Has anyone used this ? This will be more than 100 USD.
what are the results ?
Thanks and best regards.
2612614
W220 Moderator
I often find it is the actual Electric Motor that causes the grief, ;)
2005 S600
A new PSE pump is about $500, so, if I had mine apart and KNEW it was the impeller, then I would spend the $100 to find out...
Sometimes this approach works, sometimes, it doesn't.
I spent about $12 in o-rings, disassembled, cleaned and reassembled my valve blocks, and they've been fine ever since. So, you can successfully rebuild/repair a component, if the diagnosis is correct.
Please keep us posted on what you choose and the results.
W219 320CDI -07 W220 320CDI -01 W210 270CDI -01 EX: W211 320CDI -04
I bought airmatic compressor repair kit from x8r, yes they claim to be better than oem lol...
My PSE pump I bought 2nd handed, about 200鈧
W220 Moderator
Yeah, sorry I wasn't trying to suggest a new PSE complete, the Mabuchi Electric Motors are available new from time to time on Fleabay, not that dear either, fixed one of mine a treat ;)
HTH,
Thank you very much Gentlemen for the information.
So, logically I should be looking for another unit, and just it get it over with.
However since I am bored, I will try purchasing the motor and try to get around the problem.
The actuator in the boot has a leak, I would ideally want to fix that before moving forward; and the wiring harness going from the car to the boot is also broken.
Let me see where I can find the two parts.
Will keep posted.
Best Regards.
W220 Moderator
:ROFLMAO: I just fit new MB Parts rather than Chinesium, it is cheaper and far less hassle in the long run ;)
1 - 10 of 10 Posts
