85' U1300L Holset Turbo VA A/C, 66' Propane 404.1 rock mog, 1975 416 Doka, G500, Volvo C303
It really should not require adjustment. You might need to check your filters etc. You might have had a regulator spring or something fail. Or, as always it is just as likely as a gas motor to have a typical failure such as bent walves etc.
Unimog U1450
krisinak said:
i know many of you have experience with propane. i have a forklift in my shop that runs poorly. ive tried adjusting the regulator without effect. does it take a gas analyzer to do the job? thanks, kris
Sounds funny I kow, but check your radiator. The regulator is kept from freezeing in some units by the radiator fluid passiong through it. U1450
