1 - 11 of 11 Posts
Hi, problems with shifting to second gear it jerks and rpm goes a little up and down between 20-90 kmh not all the time. And gets much better when the gearbox is hot both things but not perfect.
It shifts four times to fifth gear so that's as it should be and it always shifts in 20 km h (12.5 mph) to second gear. It shifts with no jerks to all other gears.
Codes: P2502 P2500 P2404
Mercedes w211 2004 270 cdi 5g tronic
Just check if anyone knows what the problem is and write if you want a video exactly what I mean.
· Super Moderator
02 ML500, 00 ML320, 05 E500 4M Wagon, 99 ML430
Possibly a fluid issue.
Other possibilities could be the conductor plate or the pilot bushing,
but I am really just guessing.
What is the service history of the transmission and its fluid if you have that information?
· Banned
2005 Mercedes CLK320 2008 Mercedes E550 2014 Mercedes E63 AMG
Those codes are symptoms of a slipping transmission. Basically, you have the input speed sensor comparing the output speed and concluding that something is not matching up. That's why you have the engine racing up and down because your friction discs are likely worn away or you have another valve body issue. Yes, it could also be low fluid but get this thing checked out before you ruin it.
check the fluid hot and also get a sample of it to see the color. What year and mileage is your vehicle?
· Super Moderator
He posted the year and model but not the mileage.
It can be read in his first post up above, but I will
put it in this reply.
Discussion Starter · #8 ·
the car also wants to shake a lot when you take it off but it's think it's engine mounts I forgot to say that the car wants to brake by itself a bit when driving slowly and you hear a little noise and it Barrels rarely happen
2008 E350 4Matic, 2011 E350 4matic
At the least, he should change the connector, it's a cheap part and another possible cause to eliminate.
W212 350CDI -09 W219 320CDI -07 Ex:W220 320CDI -01 Ex:W210 270CDI -01 EX: W211 320CDI -04
Yep, did you check there is no oil in harness AND TCU is dry too? Hope you didn't put any Comma branded oil (Motonet sale), that is utter crap...
1 - 11 of 11 Posts
