1 - 8 of 8 Posts
, Hello, I have a problem with the low beams, when activating the light with the light control, neither of the two lights on, the position, road, rear position and license plate lights are ok ..... and I tested the fuses And they are fine. I don't know where to look at the relays. thanks for future help
Hello, this is my first post, the low beams don't work at the same time ... does anyone know how this system works? It is a 2008 ML320 cdi 4matic with self-steering bi-xenon.
any fuse? relay? I have looked at fuses in the part of the engine and trunk but I have not seen under the passenger seat.
I appreciate any help
thank you
· Outstanding Contributor
2006 ML500 2002 ML320
The head lamps are controlled by the front SAM. To test the voltage we have to see what headlamp connectors are easy for you, right or lest. Do you have right of left hand drive?
Discussion Starter · #7 ·
[QUOTE = "43sqd, publicación: 18066528, miembro: 66391"]
Los faros delanteros están controlados por el SAM delantero. Para probar el voltaje, tenemos que ver qué conectores de faros son fáciles para usted, bien o mal. ¿Tiene volante a la derecha?
[/ CITAR]
tienes el volante a la izquierda amigo gracias
1 - 8 of 8 Posts
