Hello,
I would like to ask about help for the following problem:
I have W168 A160 car with two key fobs. One of them is working fine (unlocking, locking and starting the car), but the other is only starting the car. It refuses to unlock or lock the car. As I know the key contains electronics for the remote RF (radio frequency) lock/unlock and a part for the steering column coil which is the important part for the engine starting. From this I assume that the part for the engine starting is ok, but the electronics for the lock/unlock is not working.
The other thing which I observe is that the failing key does not pass its self battery check. I tried to sync it with the car but without success.
I am wondering is there any chance to repair this key?
The electronics inside are looking fine (without dirt or any rust). I checked the semiconductor parts on the small board (The resistors and the capacitors are ok). I am not sure only for the transistor which is from the IC side of the board.
Is there someone who faced or have idea what could be done for this key?
Thank you in advance!
Regards,
Best Regards,
Regards,
Best Regards,
