1988 420SE, 2002 C180 Kompressor, 200 ML320
Re: Cooling fan
The fan has an electro magnetic clutch which cuts in when the engine reaches about 100 degrees.
Before it gets to that temperature, it will spin slowly, but this is just caused by the draft made by the pulleys going around.
Check to make sure it kicks in when the engine gets hot.
When you say newly repaired engine, has the engine had a full overhaul[?]
If so, then keep the revs down for the first 2000 miles or so and monitor the oil and water levels for the first 2 weeks.
