1 - 12 of 12 Posts
I recently replaced my OEM grill with the Avantgarde Grill. However, I had a problem openning the hood since the tounge/latch kept catching one of the strips. I was able to get around it by cutting a small piece of the strip above the tounge....not very nice but I couldn't think of any other way to fix it. Anyone else who upgraded their grill had this problem? How did you fix it?
same deal here. just put one on and had to use a dremel to cut away for the latch and cut some on the bottom corners for the retainer clips to fit.
1997 Dinan BMW M3; 1985 190e 2.3, 2013 Jeep Wrangler
http://cgi.ebay.com/ebaymotors/86-93-Mercedes-Benz-W201-190E-S600-GRILLE-GRILL_W0QQcmdZViewItemQQcategoryZ33645QQitemZ8047308021QQrdZ1
190E 2.0
cheerd RDM3, that'll do nicely!
dude seriouldy a supercharged M3 that thing must be SERIOUSLY fast!
ps sorry i know this is a Mercedes fourm! :p
Banbutcher - 3/21/2006 4:04 PM
Yeah it is quick, it is an auto, I know I get busted on alot for being an auto, but it has a 3.91 diff in it which makes a huge difference, it has the Dinan Supercharger kit, Dinan Big Bore Throttle Body, and an AA Exhaust with all that at 6-7 psi it puts out 360hp at the crank.
here are more pics
http://www.e36m3.net
93 190E Sportline
Okay ...I posted this in another but still am trying to fix the pull. I also cut away some for the metal latch but do you need to cut both top fins? I have broken the original toung and a new toung. Something is getting in a bind. Do I need to cut some of the strip as wide as the toung or just for the metal latch that is in the way? This is getting expensive!!!
1992 190e
RDM3 - 3/21/2006 4:21 PM
here are more pics
That is a beautiful car RDM3 [:)]
I know that on the W124 you have to switch to a different hood release with a kink in it if you go to the S600 grill. I don't have the exact part number.
1 - 12 of 12 Posts
