W210 2002
:confused:
HI Guys i put a brand new original MAF sensor and the car worked just fine for a week. Yesterday started to make the some shit shaking and cutting out and i'm getting tired of this. I brought it to a computer, they didn't find anything.
I did put the old MAF again, then i put the new one again and the car get stabilized for while, but then start to increased RPM without reason and wasting a lot of fuel.
I replace the air filter, and again no luck.
Any idea whats happening ??? This car start to disappoint me.
What was the reason you replaced your MAF in the first place ?
Where did you purcahse your MAF ? MAF's made by China/India suppliers are notably unreliable and amazingly often sold by major retail auto parts stores.
So where did you buy your MAF and how much did you pay ?
W210 2002
Local Mercedes dealer - 368$ + tax, it was changing RPM and shaking, cutting out before.
After the original one last a week, starts the same. It feels like is working on less cylinders but the codes are p0101, which is air circle. Its nightmare.
2001 E430 4matic
Seems like each time you touch the MAF your problem gets resolved for a week and starts again. I would very closely inspect the MAF connection. Inspect it for corrosions, broken wires ... spray with MAF cleaner, let it dry and try again. Check also for any vaccum leaks.
Connector corrosion is one good direction - also can be "seating" of the MAF on the seal especially with V8's - another cause can be contamination if a silicone spray product has been used in the engine compartment
W210 2002
Guys i checked it out, i coudnt see any vacuum leaks around MAF or other pipes.
Today starts to make the some bull sh*ts like before, cranking, hesitating and low- high RPMs.
Is anybody knows any relation between MAF, Vacuum pump and central locking ???
