Lately I have been having a problem with my keyless Fob for my C320, 2001. When it is cold like first start in the morning, i have to put it and take it out several times before it will activate the ignition and start. This has been going on for about 3 weeks now. I have replaced the batteries. Any solutions anyone???? Please help/
Cold key issue, spread the word
Hi Guys...
I had an issue where my car would not unlock anytime it was cold in the evenings. Sometimes it would take a few clicks, but as it got colder, it could take a few hours and sometimes it just would not unlock, start, etc. after an exhaustive forum research with no results, I contacted my local Mercedes Benz dealer in Lynwood, WA and spoke with Garrett. He told me that it was most likely the EIS and they had seen this before. Sure enough that was it. It was not the battery, remotes, or anything of the sort. It was the EIS and I spent about $900.00 to get it replaced (it has to be coded, keyed, etc.). Everything is perfect now, but the expense was painful. However, not nearly as painful as waiting for my car to open in the morning. If your car has other issues other than not responding to the remote, it could be something else. BUt basically, if the remote wont open it or the ignition wont recognize the key, this is it! They are great cars which is why we drive them...but sometimes we have to bite the bullet. Good luck...B
Outstanding Contributor Always Remembered RI
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see Benzworld help here:
Benzworld.org - Mercedes-Benz Discussion Forum - FAQ: General Forum Usage
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
Hi Guys...
Please start a new thread for your question on the following link;
W203 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
