slk 230
There is something wrong with my slk230...my car is auto..and it seems like today while i was driving down the highway..my car seems like it was adding more gas than what i am giving it with the pedal...let me try to give u a better exampl..say i am doing about 70mph and the rev is about mid 3,000 it seems lyke its pushing 3,800-4,000 so my car keeps juking bak and forth...then when i reached my home..i stopped the car and put it in neutral and it kept reving up and down from 500-1,300 and just kept repetition its self...if u kno a solution or kno what the problem..is please help me
2001 SLK 230
reset the ecu.... you can do that by taking the battery plug off for like 10 min.
this is my idea. im a computer guy... rebooting things 9 times outta 10 fixes it.
2001 SLK320 ; 2000 E320
Thermostat?
yo_light - 1/28/2005 2:55 PM
I had a similiar problem one time when I had my Eclipse. I would be stopped, have the car in neutral, and the RPMS would exceed 3,000. The problem was the thermostat, the car thought the engine was very cold, so inherently it gave it more gas to warm up.
Thankfully, my car was under warrenty when it happened, so all they did was replace the faulty thermostat and that was it.
slk 230
Discussion Starter · #6 ·
my car is almost 2 years old it has about 27,000 and i never had the tranny fluid flash...and every 10,000 miles i would bring my car to the dealer for the service check up...and today wen i started it bak up ..i drove it around and it was fine..nothing wrong..i set it in neutral again and this time it didnt rev..just sat there lyke how it should and was completely normal..as if nothing happen...i am gona take it to the dealer tomorrow..and see if they can find the problem..but thanks for help
2003 SLK 320
Something kinda similar happened to me once. I was pulling out of a parking lot and gunned it as I was turning. I had to make a left turn at a stop light about 40-50 feet after I turned out, and the car was still accelerating hard, but when I let off the gas, the car just kept pulling and I had to get on the brakes quick. It was weird...like a glitch with the ecu or esp or something...cause the esp was set off when I went around the corner. I don't know if that's ever happened to anyone else before. Sorry about the kinda off-topic story.
But back on topic...on an older car of mine, the RPMs used to oscillate when idling...like it was trying to warm up faster or something. But I don't remember what fixed it.
- Nik
