Folks: My Exterior Lamp Light is on, indicating that there is a light failure. However, all the lights are working properly, as far as I can tell. What to do?
Discussion Starter #2
this is triggered by a change in resistance in the line. It can be caused by either the parking lites or head lites. if you put your lites on in park mode and it comes on, just remove and clean the contacts tel it goes off. if it comes on when you put it on headlites, then remove headlites and clean the sockets and check for rust.
I had the same problem with my car. Turns out there are two bulbs in the rear sidelights.....one had failed.<br> <br> The light still works, but only using one bulb
