1983 300 SD; 2000 E320
If you intend to have your fine old W126 sit out the N.E. winter, how can you keep it from getting flat spots from the cold (if dry) concrete garage floor?
thanks
I have a SLK 230. Where exactly would you place the jack stands? The only place I know of is the jacking points under the rocker panels where you jack up the car to change the tire. If the jack is there, where do you put the jack stands?
