What do you guys suggest? Mine is in great shape and I'd really like to keep it that way - I've seen a lot of cracked ones lately and I'd love to avoid replacing mine. I searched a bit but couldn't find a definitive choice; what do y'all think?
Find a good dash protecting liquid with UV block in it. However this is no guarantee, as it seems dashes in W126's were made to crack unless covered or only parked in the shade.
A good UV protection, like Meguiars' Utilimate Protectant, window tint and a window shade will keep you off crack pretty much forever. I base this on the previous ownership of a 71 Skylark that had a dash that looked literally like it did in April 1971. I say previous ownership because I even-traded the Buick for my Benz a few weeks ago.
Can Someone tell me how to replace the drivers side power window switch in the console? I found a replacement switch, but now need to know how to get the console off, if at all possible. Thanks.
Hello, w126 300se 1989. Alternator intermittently charges. I think I found the culprit. The car kept losing battery charge. Thought it was alternator. Replaced with new. When I first did it it showed 13.6 volts. All good. Well battery died a week later after short trips to work. I check the...
G'day
I took off the right valve cover to inspect the chain, tensioner, guides and cam oilers. All appears to be fine. But I need to replace the valve stem seals because of smoking issues. I decided to change the chain, tensioner, guides and cam oilers at the same time. I made a video of the...
Then the engine and transmission from the 1984 500 SE are removed. Thru this winter it will be installed in my 1982 380 SEC after replacing timing chain parts
And as far as both cars are from the pre facelift-period it should be a relatively easy swap. But some difference it has to be, is there...
Brought my 1991 560SEL (102K) to the shop for a gas smell - the only issue it had. They diagnosed it as a bad EHA valve ($500 part).
However, after replacing the EHA valve, the car kept stalling on them. After a few days sorting it out, they said they made adjustments and it stopped stalling. I...
