1 - 20 of 107 Posts
E500Es
I am looking at a 2000 S500 with 78K miles that belonged to the local Benz dealer's wife. Anything that i should be looking out for in either short or long term?
Those that know me know that I come from the 124/126 world where things are bank vault solid and parts and repair are logical, simple and without a lot of whoha [or is that whomha?].
Any input would be greatly appreciated. My previous foray into newer benzos was a 99E55, 98 C280 Sport and 98CLK430. I now need a large car to tote inlaws around who are in the 6ft+ range. My alternative is of course a solid 560SEL.
Your help and guidance would be appreciated.
· Outstanding Contributor - Always Remembered, RIP
Zotye Auto 1.5T T600 2016
· Banned
99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
I would avoid it. It was the first model year, and not very reliable. Look at any reliability study and you will see what I mean.
Reactions: Nate D. Rector
:eek:Your correct, must wear my glasses when reading these things:eek:
2003 S500 4MATIC
Agree
Dealer told me that the 2000-2002 models have many issues and that in 2003 "they finally got it right". 2003 interior upgrade is much nicer as well. You can pick up a 2003 with about 50,000 miles for around $30k if you look around.
E500Es
Discussion Starter · #7 · (Edited)
See, this is where I keep running into a wall. I will hear about "issues" but other than first gen COMAND which folks hate for OS reasons, I have not seen DOCUMENTED "issues". I have read the consumer reviews and what I see is a hodgepodge reliability comments. Most seem to rate HIGH, on the other hand a few rate 1-2 [out of 10] but when you read their comments sometimes things don't jibe [5 batteries in 18 months - that is not a design issue, that is a dealer diagnostics issue].
I went through Skylaw's links [THANKS] and saw comments on the suspension and "first year issues" but, again not much specifics. What I did see, however was something that intrigued me. Much like on some of the other fora where mods are done, sometimes without understanding the ramifications, I have to ask how many of the issues are we seeing on this board [and MBWorld] that might be based on installed 20s which can/will affect suspension/brakes/tire wear, chips which we "hope" are will engineered and fully tested, installers that we "assume" know what they are doing.
When I see a thread that asks "what are the issues?" and the first comments back are "Dude, you need $2K headlight upgrades because they look so cool!" I have to brakecheck the credibility of the information on reliability. As Skylaw said in some post, "some of us judge cars by how they function, not by "flash" that cuts to the heart of it. What are the reliability issues in 2000, not what was cooler/better five years later. I quit playing that tail chasing game a couple of decades ago. It is ALWAYS better the next year. [/soapbox]
So what are the ISSUES. That is what I am trying to drill down to? Are there specific, empirical issues that define the 2000 S500?
Reactions: sylwedydd
Besides aimatic problems the car is very good, one thing I had better mention is the instrument cluster failure problem and its quite well documented. There was a recall on this in America, so maybe you want to check if its been replaced.
107, 115, 116, 123, 124, 126
Hey Bear, great minds think alike...I was just looking at a pristine '01 S500 with just 23,000 miles on it I think I can get in the high 20's. Like you I came here to see what the issues are.
That having been said, I am absolutely loving my '86 420SEL. Took the whole family up to the Detroit airport for our Thanksgiving getaway to FL and the damn thing is a limosine. Great for carting the in-laws around, the back seat is amazing. No issues so far.
Good luck with your search!
· W221 & Audio Moderator
2015 S550
mcbear,
You have pretty much hit the issues: Airmatic suspension and electronics. Both have improved in later years.
The '00 S500 had an upper strut mount design that tended to crack, then leak. If you looked at it carefully, you could see cracks begin to develop in the paint, in the circular depressions molded into the mount (where the air hose and valve enter the strut). Time to replace it; the "seal kit" replacement was actually a replacement of both the metal upper mounts and the seals. I experienced this problem on my '00, and it cost me about $550 to fix.
Problems with the lower strut seals are less frequent, but like any wear point (including seals in hydraulic struts in spring suspensions), they do fail eventually.
Any leak in the system can run the Airmatic pump excessively and cause premature failure, of course. But more frequently, the early Airmatic relay was a problem. If it failed "on" it would burn out the Airmatic pump - a $900 repair. If it failed "off" the Airmatic system would gradually lose pressure (faster of course if there was a leak). This problem was (and is) common. Forum contributor Oddemann has indicated recently that the relay is now made by another supplier (Hella, I think) and is more reliable than in the past. About $35 from a parts house, $85 from a dealer.
If the Airmatic system loses all inflation, the car settles to a point where the tires can damage the wheel wells if the car is driven hard in that condition; and damage the fenders if the wheels are turned. That's about a $6000 repair job but is of course caused by the owner neglecting to act on the early indications of failure.
How frequent are the failures? I have no idea of the actual numbers. However, I had to have the front struts replaced on my '05 (under warranty, thankfully - normally a $2600 repair) for lower seal leaks. I have standard wheels and OE tires (as I had on the '00). Two out of two ('00 and '05) with good roads and only about 12K per year of normal driving isn't great - but then the Airmatic system is what gives the W220 its marvelous ride and handling.
I would say that Airmatic problems are fairly common and are the weakest design point of the car in terms of reliability. They can be expensive to fix. However, knowing what to look for early, and fixing it promptly, minimizes the costs. If I were to buy a '00 today I would 1) check that the upper front strut mounts were of the newer design, and 2) replace the Airmatic relay. Maybe replacing the relay is like snapping fingers to keep the elephants away, but the relay is inexpensive and addresses what seems to be the most common point of failure. Last, I'd have an independent mechanic check the Airmatic system for leaks.
NOTE: Since this was originally posted, Arnott Industries has come out with reasonably priced Airmatic struts and better-priced airmatic pumps. The Arnott struts and built with thicker-sided air bags and better seals. The newly-manufactured Arnotts cost half what MB charges, and the remanufactured OE struts cost 1/4. I have read that Arnott does not include the ADS (Adaptive Damping System) components for adjustment of ride firmness in the new struts, but does retain them in the remanufactured ones; Arnott did not respond to my email query about this, but I would check before ordering. If true, personally, I would order remanufactured struts.
I am not at all certain that the majority of problems with Airmatic are caused by oversized rims and abusive driving. These are a likely contributing factor in many of the complaints one sees on the forums, but certainly not all. But I also note that the air (rear) suspension on two of my wife's Lincoln Town Cars also developed leaks requiring expensive repair, and she is a cautious driver. Air is thinner than hydraulic fluid. It will leak through a smaller gap. (Duh). If you have an air suspension system, it's a fact of life. At least, Arnott has brought the replacement costs into a reasonable range.
Problems with a particular engine pulley (harmonic balancer) separating were addressed by a recall. The oil pan could be shattered if the pulley let go; but if the car has had all of its recalls and program bulletins taken care of, you should be OK.
Electronics problems did occur frequently in early models. COMMAND failures were largely handled under warranty with newer units. Firmware updates handled many of the audio dropout issues (and many owners failed to recognize that a short audio dropout was an indication of a waiting voice mail message on the cell phone; nothing like reading the owners' manuals). Door control failures (loss of window controls, locks, etc.) were often caused by water intrusion when folks tinted the windows. Early COMAND nav units are now outdated (Duh) and are often compared unfairly against more modern nav systems. People are frustrated that their car doesn't allow them to switch to the latest and greatest cell phone every 6 months. Guess what? No car does. Some just make it easier, and the newer UHI and MHI systems in Mercedes do that. There is a cell phone upgrade path for the 2000 and newer models, but like everything Mercedes, it is expensive. We may have had to figure it out for ourselves, but it can be done - and it makes upgrading to the "latest and greatest" every six months much easier.
I agree fully on the lack of "need" to update the headlights, tail lights, etc. ad nauseam. I updated my tail lights because some idiot cracked one with a grocery cart (also placing a basketball-sized dent in the back fender). My '00 was a beautifully styled car that I could appreciate, and I still take pleasure in seeing one go by (as several do regularly in my neighborhood). I like white front side marker covers on a silver car, so did that - but at night they're yellow, just like the originals. My HID OE headlights on the '00 were Xenon on low beam - just like my clear-lensed Bi-Xenon projector lamps on the '05. 99% of the time you drive on low beam - so they were the same, from a practical standpoint. Upgrade just wasn't worth the cost, and the OE '00-'02 is good-looking in its own right.
I do like the slightly stiffer suspension on my '05 4-Matic, which I drive in its softest ride setting; the mid-stiffness selection on the '00 was similar. Used to the Audi sport suspension, I guess. The ability to raise the front suspension by 3/4 of an inch is useful mainly to avoid bumper scraping backing out of parking.
The earlier W220s have some strong advocates (Jayhawk being one). Yes, they were more problematic than the predecessor W140. It was revolutionary in its styling, suspension, and electronics, compared to its predecessor. I loved the W220 sports sedan feel on stiffer settings, vice the very "heavy" feel of the w140. But there were problems initially; some linger, but at lesser rates. And, as MB tightened quality requirements for its parts suppliers, many of the replacement parts have been just fine. Dealers were not adequately prepared for the new systems in many cases, and many are still not today. You are correct that poor dealer service compounded the frustrations of early malfunctions. They still do in some places. We have the same problem with our local Lincoln dealership, too. But many dealerships have caught up, and do just fine.
Rust was a problem for some - in '03 MB went to a double-sided zinc treatment on the body. There is a warranty that is greater than the original mileage for rust (if it is in an undamaged area; rust from an accident-damaged area is not covered).
The initial instrument cluster recall for the W220 and CLS was replaced by an extended 10-year warranty (from date of initial service). Instrument cluster failure stems mainly from one or more of three different component malfunctions, but they are all covered.
I cannot give you any statistics on failure rates. MB had a marvelous reputation for reliability and long-lasting cars prior to the '00 W220. The early W220 failed to deliver to that same standard. People who went from the earlier cars to the newer were very disappointed with reliability, according to JD Power, Consumer Reports, and many other surveys. However, MB did address the problems, and did improve quality control. '03 was the first year the cars were built from scratch with the improved quality components - but don't forget, the improved components were also used as they became available in the '02 production year, and as replacement parts (e.g., the metal mounts for the front struts) for older cars. The quality trend continued annually, with the '07 W221 winning JD Powers' top initial quality rating in the luxury class - beating Lexus, of course. The '05 and '06 W220s are also not far off that mark.
Look carefully at any '00 you buy. Look at its service history; if a part failed repeatedly, but was finally fixed and has been good for a year or more, it finally got either 1) the quality replacement part or 2) a dealer who had caught up with the changes - or both. Be sure recalls and program mods have been taken care of. Check CarFax for accidents and look at the car for the same (rust, broken engine mounts, missing trim, etc). Have an independent check the Airmatic system for leaks (easy to do with soapy spray at the seals and hose connections). Look at the car's general condition - was it cared for, or abused?
Last, since you're buying a dealer's wife's car, perhaps he will give you a deal on an extended warranty. Not sure he can certify it with 78K, but there are other warranty packages. Very few, if any, will go past 100,000 miles - but some protection is better than none. Best to get one that covers electronics as well as suspension.
If you like it buy it - and know you're driving a modern classic.
For more comparisons and discussions of specifics of different models, see http://www.benzworld.org/forums/w22...s-encyclopedia-start-here-2.html#post10079489
Hey skylaw, that was a pretty good write up,:thumbsup:
2009_CL63, previously 02_S500, '92_300SEL
if you love your 420, you will be absolutely blown away by W220 ride comfort, power, handling and experience.
i use to love my S320 (W140 i believe) but once i got W220 it was a difference.
i still look forward driving it every day , even after 7 months now.
· Banned
Sure, you love it, until it has to go in the shop every week and starts costing big bucks! Then you jump back into trusty timeless 420SEL and keep on going. I've driven many W220 (pre/post face lift) and I still have say that I like the W126's the best. W140 was close. The W221 I drove was impressive, but not timeless and not as reliable as the W126.
E500Es
Discussion Starter · #15 ·
SKYLAW:
Perfect. That is what I was looking for. I have the VMI on the car, all recalls are closed. Minimal work done, everything "normal" for 77K with two window lifts being the only flag I see. The car was driven back and forth from the farm in Kentucky to the house in Boca so it was serviced at one of the to owned dealers at every event.
I have a small shop that does restoration and performance on 500Es and 126 models so I have access to a MB Master Tech when necessary. He retired in 98 which is why he is not familiar with this model.
This weekend they threw the keys to the car to me to drive and decide [since I had said I would not be moving above 1995 era cars] and I had a chance to switch between a 560SEC AMG, 90 560SEL with 125000 and new suspension and the W220 and I found the 220 to stack up VERY well with the 560SEL. They are different in many ways but you can feel the heritage. I would still be in my 126 but building it back up to where I would be happy with it is just not cost effective, even at shop cost. While the 126 is a VERY good car, they do get old and things do fail.
As for extended warranty, it looks like about $2K for 20K miles. After pricing out parts for the majors that have a likelihood of failure in 20K at wholesale costs, it seems like a likely wash IF there is a failure. I am going to look into 3rd Party tomorrow but so far have not looked at that route. It depends on the subsystems covered.
Thanks again for the excellent writeup. Gives me plenty to digest as I make a decision before tomorrow evening.
E500Es
Discussion Starter · #16 ·
In-laws are the main reason for me shopping for this car. My wife's parents are in their 70s and both over 6' tall. Her sister and bro-in-law are both 6'+ so there is a need for height. I tried a 2004 XJR which drove GREAT but there was not enough head/leg room in the back.
The clock is ticking on this car, one of those dealer accounting things that he does every November for his FY so when he offered me the car at $17 I really have to take a hard look. Part of the reason is I do so much biz with them on the parts/referral/refurbishment side and part was due to circumstance of the past week with so much family that came in for mom's stuff.
It is very clean with a clean history and just normal road dirty underneath. We will see tomorrow. A third peak under the hood at the struts should do it.
Thank you so much for this information! I just won the bid on a 2000 S500 AMG from my husband's credit union---its my "dream car' and I have waited patiently for the right and affordable opportunity to buy. However its an "iffy" buying situation with 107,000 miles and no history on the car---its a repo and the price is right at 18K. It looks pristine, absolutely clean but we are playing it safe and having a mercedes mechanic check it out first before we sign. I'm grateful for your posting mcbear so I know what to ask him to check now and what to look out for in the future. Is there anything in particular about the AMG package that I should be wary of? The guy at the credit union said it says "AMG" but he didn't think it "performed" like an AMG, How should an AMG perform, what should I be expecting? I am an older "new" Mom who plans to drive it 120 miles a day 3 days a week in to Houston for work and am looking for a safe, reliable vehicle with a lot of comfort and mercedes style----I have been a student half my life and have always driven cheap used asian cars that I could afford on a student budget!! We have not test driven the car yet---the credit union has crazy insurance stipulations, we can drive in the car with one of their guys and the mechanic can come along... Any furthur advice you can give would be most helpful. Thank you much! P.S. It does not come with an owner's manual, where is the best place to pick up one affordably if we sign the deal?
2003 S500 4Matic w/staggered AMG five-spokes; replaced 1976 450 SEL
Wacky Scientist, you may have an oddball there. If I recall correctly, the first from-the-factory AMG S-class was the S55 AMG, which appeared in Model Year 2001. None of the factory AMG cars keeps the non-AMG nomenclature (e.g., S500). I'm concerned that the car you're discussing may have some aftermarket AMG content, or may just be misrepresented.
Meanwhile, your mission statement will be well suited by any solid S500. They're very high-performance cars that are also comfortable and quiet, absolutely in a different universe from your earlier cars.
I drove an early S55 AMG and found it to be a "tuner car", dramatic but lumpy compared to the S500. More recent AMG cars are better integrated.
2015 S550
Wacky scientist,
I answered in response to the e-mail you sent, but post the reply here so that others might see the response, and offer their views as well. Plus, I added some items I didn't think of this morning.
First, the car is not a true "AMG." The W220 (S-Class) AMG for the '00 model year was designated the "S55." It had a 5.4 liter turbocharged engine. See Mercedes-Benz W220 - Wikipedia, the free encyclopedia for a quick rundown. Reading the charts, only cars with the "L" designation (long wheel base) were sold in the U.S. No S350s were sold in the U.S. until 2004.
Note: The preceding is based on what I read in the Wikipedia article. Kong9999 kindly corrects this with the following: "Some small corrections to your tutorial. Per MBUSA.com, the S55 AMG first appeared in MY 2001, and did not originally come with a turbocharger. That arrived in MY 2003, bringing another 140 bhp." Thanks, Kong!
The car you are looking at probably has an AMG body kit. It looks sportier, but the car probably has a smaller engine. One thing to watch for is whether it is a rebadged S430. If you're paying for an S500, be sure you're getting one. They have a 5.0 liter non-turbocharged engine (the S430 has a 4.3 liter non-turbo engine). The AMG trim may have been an original option on the car, or it may be aftermarket. Some vendors sell the actual AMG body kit, brakes and wheels; other sell knockoffs of the kits. However, without the engine modifications and other changes, it is not an S55 AMG.
For reliability, you're probably better off without the S55's turbocharged engine.
Advice on where to find manuals is at post #15 at Airmatic On Or Off? - MBWorld.org Forums. If the '00 Owner's manual is no longer available online, you will be given an address or phone number at Mercedes where you can order a set. Note the free download for the COMAND manual on Paul Dick's website.
Some additional considerations: You will not be able to get a warranty with over 100K miles on the car. You should consider keeping a cash reserve for repairs.
Tele-Aid for you car will be analog; some '00 models cannot be updated with the digital replacement. Tele-Aid is a subscription service similar to GM's OnStar - you could call for assistance, and if you had an accident resulting in airbag deployment, Tele-Aid service would be notified of the deployment and your GPS location. Nice if you were knocked out. However, all analog cell service will be discontinued in the U.S. very shortly - perhaps within weeks. If you cannot upgrade to the digital Tele-Aid, you will lose that feature. Keep an authorized dealer's number handy in your cell phone in case you run into trouble.
You will like the COMAND better if the car was made after November 1999. It will have a "D" navigation system, for which you can still get updated CDs. See D-Nav? - MBWorld.org Forums to see a good check (but it requires at least one nav CD be available). The date of the car's manufacture is on a sticker on the driver side door sill.
Also, the CD slot in the COMAND is for the nav CD only- not music CDs. Music CDs go in the 6-disc changer in the trunk. I tell you this because you don't have an owner's manual; it's the first mistake many folks make.
Do a very careful Carfax review on the car, and be sure the dealer pulls its maintenance history (an authorized dealer can do this). As a repo, it may not have been maintained well. The records will tell.
Pay attention to what the mechanic tells you. Someone who gave the car an AMG appearance may also have driven it hard. That inevitably causes premature wear. If he gives it a strong OK, then you're probably in good shape.
If it's thumbs down, look at a good pre-owned E-Class or C-Class. For the same money you can get a newer one with lower mileage than the '00 S500; and they do not have the Airmatic system concerns. Or, you might want to consider this car - 2000 S500 4Sale: Htd/Ac Front & Rear Seats, Parktronic, Starmrk Warr $20k or b/o - MBWorld.org Forums.
1 - 20 of 107 Posts
