· Administrator
1998 Pano SL500; 1993 SL500; 2005 ML270cdi
With my 1993 SL 500 I've been having a few problems lately with engine cut outs, ASR lights showing, LHM cutting in etc.
If other members experience these problems I can only recommend reading the blue sticky and following the links on this subject.
Following Bob Terry's advice using just a simple LED I've identified and corrected the faults and cleared the many stored fault codes.
If you have to go to the stealer be very confident and tell them which persistent fault code you have identified, this will put you at the advantage of knowing what is at fault and not at the mercy of a thorough expensive diagnostic test.
1994 SL 500, 1987 BMW325es
You mention that you had these trouble codes. I am curious. Did you just clear them, and everything was fine, or did you have to fix any of the fore- mentioned,
· Administrator
Most of them turned out to be old stored codes and did not return once they had been cleared.
The one code that did re-appear was for the roll-bar axle switch which I traced to a corroded terminal.
The one I was expecting trouble from which was the LH module returned a no fault found code ;)
