1998 S320LWB
For those that have done this job: Can someone please advise regarding if we should be pre-lubricating the tracks (with silicone grease) and pivot point (with oil) a new Genuine Mercedes Window Regulator; Front Right for Power Window P/N: 140720304 prior to installation. The new one from Mercedes seems a bit dry.
Thanks Much In Advance.
Seth
1998 S320LWB
Discussion Starter #2
note this front regulator
has gear arc with No Pulleys like the rear regulator has
1994 S600 Coupe, 1995 S600 Coupe
Absolutely lubricate it liberally in every area that rotates or slides. W140 windows are extremely heavy, and any friction will make regulators fail quickly. Use a quality synthetic grease that won't harden with age.
Jon
1999 S600
I recently serviced my regulator and squirted the shit out of it with silicone lubricant. Do it. Once you seal up the door, you can't. Get it while the door is apart.
