1 - 16 of 16 Posts
ml270
hi all ..... great site i have 2002 ml270cdi, please help
2 months ago had major problem with intermittent starting.Diagnostics AT LOCAL MB garage said it was my immobilizer and transponder unit. i replaced this and the problem still present . They then changed fuel seals and line . PROBLEM still present . Then oddly when it did start it would not accelerate properly almost as if in limp mode?. they then said no 4 injector had to be replaced and IT WORKED started everytime since then for 2 months .
However, now at times it will not accelerate properly and in neutral wont rev above 3000rpm . At other times it will be absolutely fine , and hit top speeds no problem.
Ii have already paid out 650 pounds and am afraid to go back to M.B .
Do these symptoms ring a bell with anyone please?
many thanks Tony.:surrender::surrender::surrender:
Equal Opportunity Offender
2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
Please finish filling out your profile, your location, etc. But, it sounds as if it may be a diesel specific problem. I hope some other diesel owners can weigh in.
2002 ML270 CDI
Same car+year as me. Seems like your wagon is going into limp mode, which could be due to one of any number of sensors/devices which have failed. You need to get the codes read, it will store any that are intermittant faults. I had this happen once on mine, and it was the transmission controller that had an error (something about low voltage), and so then must have told the engine controller to go limp. I ddin't get a CEL up on the dash or anything, but it was obvious something was up due to the lack of power.
A good check is next time it does it, stop and switch off the car, then immediatley start and drive again, this will show up any intermittant fault if it works fine once restarted. Mine worked fine after a reboot.
When in limp mode the turbo control is disabled, so you don't get much boost and hence not much acceleration, and there is a 3000rpm limit imposed on top of this. So this fits with your description. NOTE that in neutral there is always a lower rev limit to protect the engine, I'm not sure what that limit is though, I should try it one day.
ml270
loss of power above 3000rpm
Thanks useful info , put some injector cleaner in tank this am and appears to be working but may be to early to tell. once again thanks .
ml270
Hi again, injection cleaner didnt work! how much did your ml cost? how many sensor does my car have?
thanks tony
2002 ML270 CDI
Mine is in Australia, so prices don't compare well here with the UK. Your car has hundreds of sensors.
It could be your turbo actuator is on its way out, there is an easy test for this, the EGR valve and turbo valve use the exact same vaccum transducer, so you can swap them over and see if it fixes it without spending any money at all (you don't need EGR).
As muc as I hate to do it, you should really have a look at a UK forum, there is far more CDI experience on them, for example there is a recent thread on this exact issue and exact car (it's not you is it?)...
ML 270 CDi won't rev past 3000rpm. - Mercedes-Benz Owners' Forums
W163 05' ML500
If i were you i wouldnt be very happy with your dealer hope you didnt pay them too much for the work they did that didnt fix the problem.
Power loss
I have a e270 cdi 54 reg and every know and then my car won't rev above 2500 rpm or let me manually change gears except 1-3-d the person I got it from reckons its a safe mode as I may have over reved engine or too fast lol I know think after 5 times and not going fast it maybe be trying to get answers. No faults show and the drive mode stays the same but I get overtaken by cyclists when it does it. Any help much appreciated
ML 270CDI 2002, BMW K1300S, VW POLO 1.9TDI
The person you got it from is talking BS as to the reasons for your limp mode, you can't over-rev an auto!, and anyway, the CDI engines management systems wont allow an over-rev..........You need to have the codes read but it sounds to me like its possibly the 'maf' thats causing intermittent limp, a new maf is only about £60 from MB and usually needs replacing sooner or later, after that I would be looking at the transmission that's causing limp mode and a common cause is a faulty conductor plate, this plate contains the speed sensors which are the usual culprits.........The conductor plate is located inside the gearbox and can be replaced with the box in situ. Another cause could be a leaking pilot bush, this is the large electric plug on the side of the 'box and when leaking it allows atf fluid from the 'box to 'track' inside its wiring loom and enter the transmission ecu (located inside the cabin) causing a few electrical gremlins. .
There are many other reasons for limp mode and I have mentioned the 2 most common that I have experienced.
2003 e 2,7/ 2001 2.7 ml / 2003 110 vito van.
my E class used to go into limp mode and my specialist told me to give the car agood blast on the motorway this cleans the exhaust out and im glad to say it worked, never done it since. also got a 2001 ml 2.7 that wont pull when driven hard, had car on star and no faults are shown, specialist recons its an air problem around the intercooler releasing pressure or sucking in cant remember wich. Dave.
2000 Mercedes ML-320
Are these codes pointing towards early signs of EARLY "BLACK DEATH" for my 2002 ML 270???
It still changes gears but only revs to 3000RPM and has a messy top Injector..??
I've been reading some posts indicating a Mass Flow or BLACK DEATH as seen and described on youtube, seems like a relatively easy fix.
2644690
Any Idea's?
Read Codes
C1174 MIL ON&Stored
N49 (Steering angle sensor) : Steering angle sensor is not initialized.
C1210 MIL ON&Stored
Terminal 30 undervoltage
Read Codes
P0100-1 Stored&Current
B2/5 (Hot film mass air flow sensor)The signal voltage is too low.
Read Codes
B1108 Stored&Current
M13 (Heating water circulation pump) / M2/2 (Module box blower motor)
B1206 Stored&Current
M2/12 (Rear shutoff flap positioning motor)
W163 W202 W203 W246 MB100D
I would be focusing on that P0100, seems to be a good lead to what's causing the issue.
Maybe live data can read actual voltage values? From MAF.
Would also check all wiring to MAF (and clean with MAF cleaner?)
if possible swap with known good one.
Good luck.
Good luck.
Great! Thanks a Million I'll give it a shot
btw, from this discussion,
"C1210 is Terminal 30 undervoltage. Check your battery voltage - you need 12.6v at rest, and about 14v with the engine running. "
1 - 16 of 16 Posts
