The power windows, all but the front passenger side, decided not to work. I checked the fuses, which are fine, so, on a whim, I replaced the switch combo for the driver side with a used switch. Now both front windows will work, but both rear windows still do not. <br> <br> I noticed that one fuse controls the left front and right rear windows, and the other fuse the right front and left rear. Does this mean, that if one switch is bad, then that would affect the whole circuit? Should I replace both switches with new ones? Or is there something else that could be wrong? <br> <br> THANKS! The weather is starting to get nice and I really want to put the windows down.
