1985 380sl - charcoal grey w/lt grey interior
all,
have had a pretty good sized leak from the power steering on my 1982 380sl - not sure where exactly but will investigate next week.
*was wondering if there is a common area on the steering pump or hoses to start the search??
thanks in advance.
Previous: 1989 190E 2.6, 1997 E420, 1985 380SL, 1975 450SLC
This same thing happened to my '75 450SLC not long ago. Lots of smoke from fluid on the exhaust system.. especially on uphill climbs. I couldn't see where the leak was as it was apparently buried under other components on the driver's side. So into the shop it went.
$700 later I had a new power steering hose, p/n 107 997 20 82. One side connects to the pump but I can barely see where the other side connects (to the PS box, undoubtedly). Certainly a job better left for one with a lift.
1986 560 SL
I think that high pressure hose is a common failure item. The part sells for about $100 last time I looked. Installation is a bit awkward but not worth $600 for pro labour. You can DIY w/o a lift.
anyone have a photo or can show location of this high pressure hose?
