2001 ML320
Hi Guys, Im losing power steering fluid from from my 2001 ML320. The leak appears to be coming from one or two hoses that have fittings at the back of my steering rack by the pinion gear. Anyone know what the part numbers are for these two hoses? Thanks!
2612651
2001 ML320
It's 4JGAB54E51A223871. I assume I should replace the o rings too. Part numbers on those would be much appreciated.
Dallas, Texas
When putting in your VIN Xentry shows lines with banjo fittings at the rack. Bummer.
#100 163 460 22 24 HP line from pump to rack
#105 025 997 73 48 o-ring HP line to rack
#110 025 997 75 48 o-ring HP line to pump
#123 163 460 52 24 return line to radiator
#125 025 997 74 48 0-ring return line to rack
Both of the lines used to come with o-rings and hose clamp. Do not buy junk. Genuine MB or Rein only.
