Hi all, im new to this forum so apologies if i've posted this in the wrong place!
I have a ML320 W164 2009, and have been having issues with my steering for a few weeks now, and reaching out for help.
Over the last 3 weeks, the steering has slowly started to get stiff and now its like i have no power steering at all.
I have checked, and there is no leaks (that i can see), the fluid is at the correct level, and is not really moving. There is no noise when turning, no knocking or whining. Ive turned the steering fully to the left and right and this worked initially for about 2 days and then the issue came back worse. I have booked in with an approved mercedes garage, and will be plugging into the star diagnostics, but not confident it will show me any mechanical issues? - could it be something as small as a faulty fuse?
From what i have seen on other forums etc, i think there may be air stuck somewhere given the symptoms, but hoping somebody can assist in how i could check/remove this, or help in any way
thanks
thanks
