98 230 SLK
I have tried to replace the pressure power hose and I don’t find any necessity for it. The area is dry, where the power hoses attaches at the pump end. The power steering fluid is still leaking on-off with very small amounts. I can't figure it out where is it leaking from. Does the pump have more hoses besides the one u see on the pics? or does the power steering pump has a small crack or hole from the corrosion? or the pump has a gasket leak? I am not even sure if our car has a gasket in the power steering pump. Share your experience with me please.
Thank you in advance.
Dr. Mers:bowdown:
Theck this link for pics
http://www.benzworld.org/forums/r17...ng-hose.html?highlight=power+steering+SLK+230
2002 SLK 230 1986 560SL 2008 Honda CRV
Hi Dr.
If you don't see any leaks around the pump from the top try looking for the leak from underneath the car. Follow the lines, also i'm sure you did this already but check the gasket for the cap.
'01 SLK230 Kompressor, '95 C280, '98 BMW 528i, '86 BMW M635CSi EURO, '87 190E 2.3-16
The hose on the low! pressure side leaking a bit on mine. It's clearly visible though.
There must be some sort of seal on the front of the pump.
Try cleaning all the oil off of the pump and drive it for a while - the leak will be obvious.
98 230 SLK
Privet
Ya tak i zdelal Bratok. Prosto vremeni ne bylo zalest' pod mashinu. Spasibo za sovet!:)
