So the drivers side seat base (where your bum goes) is only tilting on the outside. The center side seems to jam. Does this unit have two motors? Could one be dead? I haven't ripped it apart, just peered nervously underneath.
Yeah, I'm worrying mine will be back.I fixed mine as well. It had exactly the same issue. Only, the cable worked its way loose after a couple of days, so I put some JB Weld on the end and insert it into the worm gear again. It hasn't come loose yet and it has been in there a couple of weeks. Time will tell if it will hold.
Yes!Did you guys have to remove the seat to do the fix?
Heh! For some reason, everyone of your posts are a mystery to me.Actually I didn't. You just move the seat all the way forward revealing the gear housing on the seat rail. Pull the plastic cover off, open the gear housing and you are there. I guess it would have been a bunch easier if I had removed the seat. I am not a big person so maybe that is in my favor.
Ahhh, now I understand...
