I'm experiencing power loss after the vehicle has been running at operating temps for a while.
What I mean by that is; Normally, when run from a cold start, at 3/4 throttle she will accelerate properly, rpms increasing, retarding the shift points correctly, allowing for brisk acceleration. Well, as brisk as it gets for a 240.
At 1/4 throttle, she accelerates properly, going through the gears at lower rpms correctly.
However, after having run at higher speeds for a while, I can't get her to respond to 3/4 throttle. Even when I'm doing say, 40mph, and I depress the kick down switch, there is no downshifting. I know it's not the kick down switch because the kick down works fine when she's run after a cold start. There is no throttle response after she's been run at high speeds for a while.....very frustrating.
I have no idea what might be causing this? Is it a throttle issue? Transmission issue? Anyone have any idea?
