21 - 25 of 25 Posts
90 420SEL, 00 BMW X5, 00 Lexus RX300, 01 Chrysler Town and Country
Discussion Starter #21
Yes, either the wiring or the buzzer contacts to the drivers door...got to pull out the buzzer from the junk car, switch and see.
Outstanding Contributor
1989 560SEC, 1989 560SEL, 1995 E420
Yes but swap the switches first! So much easier and who knows what you'll find?
Discussion Starter #23
I had shorted / joined the two wires going to the door switch. No joy.
Discussion Starter #24
The flasher is one of the functions of the multifunction relay. That relay is rectangular and resides in the fuse box.
Is the multifunction relay the rathaer long rectangular relay in the fuse box? THe one which has pins as well as wiring going to it. When I unplug it, the pins do separate but a binch of wires still connect to the relay (pins are in the center and the wires are on either side). I could not see how to disconnect the wires but I did not look close enough to figure it out either.
Here you go:
2644611
21 - 25 of 25 Posts
