1 - 1 of 1 Posts
2009 C350 (wife), 1995 E320 (son), 1995 S320 (mine)
OK, getting a slight ruff idle at a stoplight and a little of a rough start when cold. I am suspecting LAMBDA adjustment but thought I would check vacuum first to eliminate it.
At the vacuum hose to the power breaks I get 26 Hg and then it slowly fluctuates between 25-27 after a minute. This is above (or below) the 22 Hg I should be getting.
Any suggestion on where or what to look for? Is it a leak or a blockage? Is it in fact OK and the LAMBDA is off and causing the fluctuation?
Any help is greatly appreciated.
Thanks in advance.
Clanster
1 - 1 of 1 Posts
