I'm curious if its possible to add a subwoofer to a 2001 CLK 430 with the Bose system. I've read that it uses some sort of Fiber Ring. Is adding any subwoofer even possible or would I have to remove the entire sound system and replace it all?
Re: You can tap the output of the stock amps to go into a high-level input.
Do I run 2 RCA cables from the stock amp into a new amp dedicated for the sub? Or does the stock amp have enough (doubtful). Also where is the stock amp located?
