2000 ML320 LHD
So I got a new problem.
I occasionally do not feel that elastic feel/ recoil in position 3 in attempt to start the vehicle.
This has happened twice beginning yesterday.
You start the car, turn off later & can't start back right up. After 3-4 attempts the recoil drag in position 3 returns & then cranks & starts.
No code on scanner.....
What are your thoughts about this symptoms?
Outstanding Contributor
2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
To restart immediately, you must turn the key all the way back to position 0 first. This is the design of the system, to avoid starter operation when the flywheel is spinning.
The spring that returns the key from position 3 is inside the ignition switch (black and white plastic cylinder), not anywhere around the lock cylinder (metal cylinder with keyhole).
If you occasionally turn the key to posiition 3 after insertion, and get no crank on the first attempt, then the day you replace the ignition switch is fast approaching.
2000 ML320 LHD
DrX,
would this be the correct P/N 168 545 10 04?
Yes. Photo thanks to soloprop77
2622126
