1 - 10 of 10 Posts
94 E420
Okay, so I go out yesterday morning to warm up my car, fire it up as usual and turn on the headlights so I can see where I am going after the light on the garage door opener shuts off. I noticed that the indicator on the dash for a burnt out light bulb is on [:O] I take a walk around the car, they all work. I tried the brake lights, turn signals, hi-beams, etc. Everything works. Then a few minutes into my drive to work, the dash board indicator light goes out. Then it did it again last night.
I am confused, any ideas?
Colorado
hi
chance the fuses from the dashboardlight under the hood and in the daschboard there is the pin to reset your milecounter or die other one.
if you turn that pin, your light in the daschboard go burn harder and softer while you turn it.
perhaps you have to spray it with WD-40 behind the clock
sorry if my englisch is that bad[V][V]
grtz.Wallietax
I have the same problem with my 1988 260E. Except I had a tail light go out. I replaced the light and still have the indicator light on no matter what I do.
2006 S500 AMG Wifes Rig Hillbilly Girl 02 ML320
Hey Colorado! There was a guy on this forum who did a writeup on this problem. I THINK it was Nordstern but don't hold me to it. Pretty sure it has to do with resistance. When I put on my rear spoiler that had the brakelite in it I get the same thing. The car is reading that extra lite and because of the extra load it thinks a bulb is burned out. [:(] Maybe someone else can remember that post.[?]I went back looking for it but man there are a lot of posts on this board.[:)]These cats lke to write!![;)][;)]
Smokie
95 E320 Cabriolet, 140K
I had a somewhat similar mysterious problem like that, which turned out to be broken wiring at the trunk hinge.... part of the brittle insulation problem we have to live with.
300TE 4-Matic 300GD
Hi Colorado.
I did write a piece about this. I think there might have been more threads though. Don't remember.
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1196972&posts=9
Regards
Geir
Dang it was you Gier ! "OLD TIMERS" ain't got me yet!![:D][:D][:D]
Smokie
I know you checked the lights, but did you also check the license plate light?
I had the same indicator light driving me crazy and it turned out that it was the rear license plate lightbulb which I of course always forgot to check.
Matthias
YEEE HAAA !! GIDDYUP[:D][:D][:D][:D][:D]
Smokie
1 - 10 of 10 Posts
