1 - 8 of 8 Posts
Unimog Moderator
250GD Wolf
Anyone know the ID and OD of the Portal breather hose, the rubber part that goes on the front portal hard line to the hardline on the axle? (basically what do I ask for in NAPA?)
One of mine has cracked and I cut it and fixed it, but its a little short and I don't trust it since its probably due to be changed just because of its age. I'm going to pick some up when I'm in the city today, but my old one is to swollen/old to get a good measurement.
85' U1300L Holset Turbo VA A/C, 66' Propane 404.1 rock mog, 1975 416 Doka, G500, Volvo C303
I can't help on size, but I would consider vacuum line.
The portal side is easy to yank off in the parking lot so you can find the right size in the store.
U1550L/37 Doka, U1700L/38, Merc 1017A
i've used 1/4 ID hose before. try to get a fuel line or something with good structure for durability.
Thus vacuum hose.
Unimog Moderator
250GD Wolf
If its worth doing, its worth doing right
After going to NAPA and seeing the OD of the 1/4" fuel line they had (it was pretty thick walled), and that 1/4" is 6.4mm, and striking out at the local Mercedes dealership, I hopped online and did a little research. VW's (the older ones) use 5mm fuel line, so I contacted an independent shop in the city that is well known and specializes in the older VW's, and they had 5mm rubber, with braided protector in stock (bulk, so any length I wanted), so I had my buddy pick some up since he was in the city. That should last as long as the factory stuff.
1 - 8 of 8 Posts
