1 - 9 of 9 Posts
My 2003 E320 (W211) has an anoying 'pop' sound when going over speed-bumps and such. It has new aftermarket Bilstein struts and the MB Dealer said they were fine, as did a good suspension tech I know. He heard the 'pop' and determined it was not due to the Bilstein struts, bushing, or ball-joints. Seems to be a mystery ... however, I have discovered that if I go over four speed-bumps - two slowly coasting and two with breaks slightly engaged - when the breaks are slightly engaged, the 'pop' does not occur.
Strange ... anyone have any thoughts as to what this may be?
Thanks -
I just bought an 03 E320 and noticed the same thing. However, my car was essentially a CPO, so (perhaps mistakenly) assume that if there were a big problem, MB would have fixed it.
... hmmm - interesting. Please update this thread if you ever find out what the problem is! We have eliminated many things - have you tried holding the breaks just a bit while going over a bump? Try that ... we could be on to something.
I'd guess your new aftermarket shocks are loose, i.e. bolts not tightened correctly.
Yes, it's not the components, it's the installation.
I'd guess your new aftermarket shocks are loose, i.e. bolts not tightened correctly. Yes, it's not the components, it's the installation.
Could be - I wonder if JeFe95 has after-market struts ... the MB Dealer did tighten a lose bolt on the front drivers-side but didn't notice anything on the passenger-side.
Why would applying break pressure make it go away if it were the struts, though?
Thanks -
I know exactly what that is. Your rear seat headrests are hitting. Nbd. You'll notice the sound does not occur when the rear headrests are up instead of down.
Oh wow haha. Do you know how to post your own posts? I only know how to respond. I have a problem where something under my car issuing a dinging noise, I took a picture. It's not my cat or muffler. It's also not my heat shield. Any ideas? It's coming from one of two of these cylinder things closer to the engine.
Welcome to the forum!
To start a new thread go to the correcct forun for the thread i.e. w211, w124, w210 etc. Click on 'New Topic'.
Cheers
1 - 9 of 9 Posts
