What do you use to wipe it in with and wipe it out with so it wont scratch the wheel.[urlhttp://www.formymercedes.com/wheelcare.asp[/url]
Take your pick[][
I got the metal protector and a metal polish and it works for me.
If your wheel is clean, the metal polish is not necessary (unless you want to clean the inside, or want to clean brake dust stains off). The metal protector forms an invisible resin which seems to resist brake dust much better than normal wax/polish, which burns off far too quickly due to the heat from the brakes.What do you use to wipe it in with and wipe it out with so it wont scratch the wheel.
Try e-mailing [email protected] and asking them. My guess is that it should be, but you should ask to be certain [thanks for the info, but is it save for a polish wheel?
from their site. You only have to wait if they do not have the item in stock (e.g. special order). My guess is that they will for something as common as this [thanks drew.. i will.. []
is there any other web that i can buy online? i don't like the way formymercedes take order coz i have call them and wait.. [|)]
