05 E55
The piece is very hard to see. Pull off the engine cover and it is located ON the engine on the drivers side about half way down. You just have to know what it looks like and where it would be. I think its right where the engine meats transmission. your going to need a female torx (star) sockets. ( @$7.00 at auto zone)
The socket size is Cr-VE8.) Use your hand to place the socket on the bolt then put your rachet/extension in the socket and turn.
to remove a screw then pull it out and re-screw and your done. The piece commonly goes bad it stops working whenthe car gets hot.
