1 - 1 of 1 Posts
I just replaced my ignition switch, tumbler, cover - the whole setup..
Upon installation, although the key now turned and started the vehicle, it did not unlock the transmission from Park position...
The cable that leads to the brake is definitely working, but the cable to the ignition isn't..
i took the cable out of the ignition and can manually press the linkage in effortlessly and the shifter is released.
But no matter how i install back to the ignition, when keys in/out/turned the new ignition does not release the transmission from park!
Please any help.. im about to remove the linkage altogether and id rather not
1 - 1 of 1 Posts
