Current 2004 Mercedes Benz CLK 500, Previous 2005 E55 AMG, Previous 2009 S550
I've Searched and searched and have come up short.
My '04 CLK 500 has come along way since purchasing it over a year ago. That's for another thread.
I continue to sporadically receive this message on my cluster (see picture). Sometimes when it's hot, cold, just restarted, been off days. Just driving, turning, sitting etc. Completely random. At first I thought it had to do with turning as straightening the wheel it would go out and come back again when turning. Restarts made no change, clearing all code etc. Unhooking batter also no change.
I have a Carsoft MB II and a copy of WIS. I have found nothing that helps.
I have replaced both steering wheel electric adjustment motors, relubed all linkage and checked all connections. Nothing else is wrong or giving a warning.
I replaced both seat ECMs because of seat adjustment issues. I thought that would fix the issue as the controls for the steering wheel adjust run through the driver seat ECM. No change.
Here's what I know. Both adjustment motors work as designed. All seats work properly and all easy entry setting also work. When I scan with the tool I can see commands all being received and sent properly for adjustment of steering wheel.
I suspected a bad clock spring. I relearned the steering angle through the scanner and that had no affect.
It's very random. Very annoying because it can't be cleared, it has to just go away.
In case anyone asks, obviously it's electric adjustment as I know the manual adjustment can cause this issue.
HELP!
HELP!
