On your car it's behind the air filter box on top, center. Search the forum for pictures. Just don't confuse 2002C230 with your, different engine, different MAF.
What more likely happened is when you take short trips, the engine doesn't get a chance to warm up, it leaves moisture deposits in the combustion chamber and next time you start it you may see the water vapor in the exhaust and the engine may stumble a bit, all normal. Or it could be CPS about to go out, time will tell.
