I have a 2008 Mercedes e350 V6 the problem I’m having is the car won’t crank at all anything it has power for the main wire to the fuse boxes but none of the fuses have power I’ve checked the box under the hood and in the trunk neither one has power to the fuses car won’t do anything the lights come on on the dash but that’s it
Purple Moderator
Even if there is not a check engine light on it would be best to have the car scanned for codes with a scan tool that can read all MB codes.
It is better to help diagnose this and sure beats throwing parts at the car based on speculation from forum members until codes are checked.
2008 E300 4Matic
If the battery is low on voltage due to a bad cell, you will still get the lights on the dash but 10V won't be enough to crank the engine. So, when you say "has power" are you sure it is at least 12V?
