C240 Rwd 4dr Sedan (2.6L 6cyl 6M)
Just tried to start my '03 c240 and the ignition doesn't seem to be recognizing my key. After trying several times the key finally turned so I thought that my key may be going bad. However I wasn't sure because it had unlocked my doors. After being inside the car I tried to turn on my wipers because it is starting to rain but the wipers did not work. I also noticed that my high beens will not come one and my day time running lights are not working either. If I turn the lights all the way on my low beams and my fog lights do work but the high beams still will not come on. I tried to use the menu controls on the steering wheel and they also are not working. Also after being in the car for a few minutes my display went out completely. I am trying very hard not to be nervous but its not working. Can someone please tell me what this might be. I am praying that it's just a fuse...
Zotye Auto 1.5T T600 2016
Check your battery, it must be more than 12v any less and all sorts of electrical faults appear.
Eric everything else seemed to be working ok. The interior lights locks radio. Once I got the key to turn the car started and I did drive it around the parking lot and it seemed fine.
Start checking the fuses then.
