05 ML 350 SE
I know that you have to rewire the Bi- Xenon for 2000 model and older. What will you do with 2005 model when upgrade from halogen? If so, how can you identify all the wires. By color? Please help. thank you!
On 2002+ models, the OEM bi-xenon assemblies should have the exact same plug connection. However, you will have to visit the dealer to have the AAM programmed correctly tyo make them work.
- RODNEY
05 ML 350 SE
Thank you very much. I'll contact the dealer for reprograming the AAM after installed. Again, thanks for you respond.
