2016 E400 4Matic Sedan
As I said, A/C is leaking again and the regular shop is running out of options. More than likely I have to send the car to dealer to have it checked out.
Got two favors to ask the board. I heard that "if you can't see the dye.... then it's probably the evaporator....". Is it ture? Somehow I thought you would see the UV dye at the water drain from under the car.
On the attached picture, would you please tell me what are those two lines (marked with red arrows)?
Depends on the day!
Nope...they are the fuel lines running to the fuel cooler. If the picture were a bit wider you would see them feeding in to the fuel pressure regulator and Fuel distributor[;)]
I look at these bloody cars all day and many nights. 5 560's and you get familiar w/ the fuel system.
Jonathan
