Mercedes Benz 1997 E320
I have an MB 1997 E320 L6. I was changing the spark plugs yesterday and the yellow hose is so brittle it just breaks. MB dealers is close today so I'm trying to know more about these in the mean time. Does anyone know what is the functions of these hose? Sorry I'm a total newbie and knows nothing around cars.
1999 e300 Tubo Diesel
Hi, that the EGR (exhaust gas recirculation) valve. Its not a rush fix unless you need it to pass smog. it helps re-burn hydrocarbons at low temperatures (startup). You should get a new clear pipe to where the to other end is. It should be fine to drive.
1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
The egr
on your diesel is vacuum powered, repair that line or you will have stalling problems from an open to atmosphere leak.
ohlord:bowdown:
Discussion Starter · #5 ·
went to Autozone and found the exact OD tube for $5 and have it replace in 5 minutes. Thanks to this great forums as it have save me so much money.
Good
job:thumbsup:
be sure to inspect all the other hoses and vacuum lines.
ohlord:bowdown:
