Guys,
I am back again asking for some help with my SEC. I have two things I need advice/help with. First is my suspension.....
I have replaced my rear accumulators and flushed the hydraulic system with factory parts and fluid. I can't seem to resolve a clunk in the rear over consecutive bumps. When driving and going over bumps, I get a clunk in the rear. Kind of sounds like having a brick in the trunk. I have checked all components except the rams themselves. My research says they are just rams... No real "shock" ability. I have checked the links/bushings etc... Ride height is 13.4 inches on both sides from center of rim....
The other is in regards to cold start idle. When first started, no matter what temperature... Idle is about 750 at idle. It slowly increased to about 950. I have replaced ALL intake gaskets/hoses/plenum gasket/lines/elbows/IAC... Again all with factory parts from Mercedes. Runs great otherwise. Just high idle...
