1988 420SE, 2002 C180 Kompressor, 200 ML320
Re: Oil leak
Nawaid
Am I correct in assuming that your mechanic took your engine out to repair it and seperated it from the gearbox?
If so, the problem will probably be the gearbox front pump seal which has more than likely been damaged in the process.
If he has replaced this each time and it is still leaking, check the torque converter where it sildes into the seal to make sure it has no burs which could be ripping the seal.[
Nawaid
