I have a 93 190e 2.6 that has a real hard time starting when it's cold. You have to hold the gas down when you crank it and let off the gas for it to try and kick. You have to play with the gas back and fourth like this for it to finally sputter and kick to where it will hold an idle. After it warms up it's fine. I was told the cold start system wasn't functioning.
What I've checked so far is the voltage at the cold start valve when cranking the engine. It's reading about 2-3 volts for a few seconds when the engine is trying to get started and drops down to 0 volts after a few seconds.
I have replaced the cold start valve with a used one that is suppose to work. I have also replaced the fuel injection thermo sensor (picture: http:www.belletc.net/temp.jpg) because I was told this might be the culprit. But the problem with this sensor is that it has no directional groove or specific way to plug it in. So it will plug in any of four ways. And although the plug from the harness is numbered, the original sensor had no numbering on it, and the new unit has a number two stamped on the side, but it's exactly in between two pins. So there's no way of knowing which way this plugs in. Does anyone know which position to plug this in?
So I tried plugging it in 4 different ways, but the result is the same... I always get 2-3 volts at the cold start valve. So it leads me to believe that this sensor has nothing to do with the cold start valve.
So my questions are; which is the right way to plug this sensor in? And where should I look now for my cold start problem?
I've also looked at the two fuses in the overvoltage relay behind the battery and they're both good.
Thanks to anyone who can help me out here. I'm pulling my hair out tring to figure this thing out and spending money on unneccasary parts in the proccess. Two things I don't like doing.
Discussion Starter #2
I just had somthing happen. I was starting it cold and it was doing it's usual thing sputtering up to where I could get it to idle while holding my foot on the gas... and then somthing "clicked" under the hood and the idle smoothed out and shot up to about 1000 RPM, like it's suppose to be. I think at that exact moment the Check engine light flashed on then went off. The "click" sounded like it came from the passenger side of the engine compartment.
Any ideas what this could be?
Edit/Delete Message
