1 - 20 of 35 Posts
500SLC #2624. Black on Black.
Hey,
Does anybody know where I can get the white plastic grommets that go inside the holes on the top of the windscreen that the hard-top/soft-top connects into.
Part numbers might be useful too, if anybody knows them.
Thanks in advance,
Foto.
71 280se 3.5 Cab, 06 C230, 06 ML350
Good find. I was searching and couldn't find it. Who would have thought to look under covering and lining/instrument panel?? :confused: Surely not me but good thing Chief was here. That's why there should only be one Chief and many Indians:thumbsup:
Sometimes EPC is strange. I'm German and I don't get what they do many times.
That's why I love this forum! Fast and reliable.
It's a shame it's so droll and humourless though. :(
I found my heater hose under Engine Suspension for my 96 SL600.
I found it now, but under 'Covering and Lining/Front panel pillar panelling, lining on floor and footrest'
1986 560SL 2002 Toyota Camry 1993 Lexus ES300
Can anyone post a picture of these installed? My 560SL doesn't have them, and I can't see how they would go on. PO beat the heck out of the aluminum surrounding the holes. Does the aluminum piece across the top have to come off to install the grommets?
They have a cut out in the center. You just pinch them, slide down a little in the hole and they lock into place. 15 seconds a side max. Just buy them and all will be clear.
If it is as beaten as you say, you might have to gently pry up the edges to insert the grommets.
2010 Mercury Milan Hybrid, 1993 BMW 325i convertible
I'll be the sole dissenter and say forget about the grommets. I've been through six of them, three on each side. My car chews them up and spits them out. It doesn't want grommets.
1986 560 SL
I put new ones in a few months ago.
I couldn't get one of them to fit just right and it has since disappeared.
My aluminum windshield header looks like someone has taken a ballpeen hammer to it. The PO must have been impatient with raising the top.
I know how she felt..... the top is my biggest beef with the 107 design.
2008 C300 (sold), 1987 560SL, 2007 CLK350 Cabrio, 2011 E350 Coupe. ALL 040! :)
Sorry to ressurect....
Does anyone know if the aluminum strip on top of the dashboard can be replaced and at what cost? Ours is pretty beaten up as well and the o-ring seals will not stay in place!
It Is What It Is, Dude
Threadus Resurrectus isn't really frowned on around here. And I'd like the OP's thoughts on his original question. :D
Oops! sorry, I found my answer finally in my search and deleted my original post!
1 - 20 of 35 Posts
